I agree with @RagicSolutions, field level access control would be a huge upgrade for Ragic.
This would not only cut down on the need for multiple sheets but also cut down on lots of secondary work related to changes with multiple sheets.
I would like to suggest an addition/alternative to this issue which would be the ability to define range level access rights on the Form Settings panel. This way you could just simply define sections of the sheet that are visible to different levels.
