Please make it possible to mass update multiple select fields without destroying their current settings. I’m really surprised that this isn’t a capability of Ragic and can see many instances where you could use this functionality and sadly the only work around I or Ragic support can come up with is to export data.
I would like to filter a group of records and set a checkbox without removing other checkboxes.
Perhaps the mass update dialog could have an option to append or delete existing data. I could see this functionality being useful on other fields as well. But for some reason I find this current limitation to be especially frustrating and non-intuitive.
I asked for similar functionally about a year ago.
In case anyone else comes across this issue I suggest a quick look at airtable’s batch update which has quite a few options for dealing with this scenario, including one that allows to add or remove specific items from a multiple select field. I could have tried to accomplish this in excel but would have had to do a fair amount of work to do so. This route is the next best thing to being able to do it in Ragic.
