Limit/Filter Subtable Rows
Hi Ragic Team,
WE are experiencing high latency due to the number of rows in the subtable. Can you please add the feature where it shows only 25 rows at a time? the same way you have on the listing page.
Thank you
This feature is in our development queue, however, it’s a bit difficult to implement under current structure. Maybe it will take more time to figure out the best solution, we’ve add you to the notify list and will keep you posted in this thread.
During this period, we suggest using Section, which is related to this topic, it may reduce the latency when it comes to big subtables.
Another way, you could create a new sheet from subtable and manage the data on the new sheet.
See the following thread as well, may be helpful…
