Hello, how to setup checkbox as radiobutton for subtables?
Radio button for selection field is not supported in Ragic currently.
Sorry for the misunderstanding, I thought you were asking about “how to” set up radio button for selection field and that’s why I replied it’s currently not supported.
Amy
I’m sorry if misled, English is not my native language, just trying to help make the product a little better …
Hello, in subtables for checkbox field we have “Unique in this subtable” options. Can you add automatic behavior as radio buttons in a subtable?
We’ve supported two new icons in the checkbox field which can work as a radio button. You can input “circle” and “dot-circle” in the choices list to have these icons and please set the default value. For example:
In case you only want to let users “check” one option, you can create a regular free text field with IF() formulas to count how many dot-circles you have in the subtable. For example:
Then, apply the validation and error message if necessary:
In the future, when users check more than one option in the subtable, they will get the notification when they save the entry.
