Does anyone know why the where in a URL works when asking for JSon but not for CSV data?
This works:
https://www.ragic.com/myragicsolutions/mtime/4.csv?APIKey=…&where=1001062,eq,Yes
But this does not:
https://www.ragic.com/myragicsolutions/mtime/4?api&APIKey=…&where=1001062,eq,Yes
Thanks
They should work, we will probably need to see the actual call to find out why it didn’t.
We are releasing and app that makes these calls to Ragic and with this not working this is causing a lot of traffic and also processing both on the Ragic side and on the customer side.
Please can someone look into this ASAP.
Thanks
Support and development this is not affecting two clients please can this be looked at urgently.
Thanks
My apologies, not sure why I always missed this post.
The reason is pretty simple, where clause is only supported on our API, not on CSV URLs. CSV URL is not part of our API, I believe they are only generated when you do a publish to the web. They actually don’t support any of the HTTP API parameters.
It might be something that we can support in the future, but that will require a whole implementation of the where parameters. This is not bug that we can just fix, it’s just not supported yet and where parameters are not processed at all for CSV downloads.
