Hello,
I recently was working on a sheet that contained two Link & Loads to the same sheets (and I could navigate between both Link & Loads using the drop down box found just below the “Exit Link Manager” found at the top righthand corner of the page). However when I tried to set the “Keep loaded values synced with source” option, I found I was unable to do so differently for both. By that I mean I wanted to set one of the sheets with a Link & Load that had a specific “dynamic filter”, and the other without such a filter, and was unable too. So my suggestion here, is that Ragic is made to be able to set different Link & Loads for each sheet, so that “keep loaded values synced with source” for instance can be selected for one Link & Load, and maybe not set for another. That is, if this is at all possible! If not, then I will like to suggest that a notice is included next to the “Keep loaded values synced with source” stating that different Dynamic Filters cannot be set separately to each Link & Load and that the “Keep loaded values synced with source” setting goes for all Link & Loads set between any single pair of sheets.
Kane
