I need to filter a drop down based on the first 3 letters or so entered in another field. I need to use “like” so if the user enters “May” the choose referring member drop down would only display “Maylone” and “Mayberry”. I’ve searched help for using like in Ragic but have not found any articles. Thank you!
Hi Gina,
You can use the left sidebar, find the field that you would like to search on, and click “Filter By Text”. When the exact search is not checked, it’s doing a “Like” search.
