It would be great if the UI allowed the user to hit return/enter after searching a string in the filter section. Currently after the text is entered the user has to then click ‘Search’.
Hi David,
Thank you for your suggestion. We will be adding support for this very soon. Appreciate the feedback!
We have just added support for this on all our servers.
Don’t think it works in fields that have a tolerance. I.E. filter by weight from X to Y KGs
Thanks Jeff! I only just checked back on this thread and it’s been released!
Nice work!
I also find this function more instinctive! thank you for this suggestion.
Meanwhile, I appreciate Ragic’s quick reaction.
