Unique Field Values Vanish, Is this a bug?
After pressing the button “Apply all formulas on this sheet to all saved records”, values on a Unique Field after the execution. This Unique Field is being used as a reference to a Link Field on another sheet. Some of the entries have blank or no value stored in the sheet. Does anyone know why this happen?
Hey! Thanks for bringing this up — this is definitely worth looking into more closely.
Unique field behavior can be affected by a number of factors depending on how your sheet and linked fields are configured, so it’s hard to pinpoint the cause without seeing the setup directly. To help investigate, we’d recommend sending a support ticket to support@ragic.com with the following details:
  1. The URL to a sample record
  2. The name of the unique field in question
  3. The exact timing when you ran the “Apply all formulas” action
That way our support team can take a closer look at your specific configuration and give you a more accurate answer. Hope we can get this sorted out for you!
