While changing form designs, layouts, etc, is there no way to undo or redo changes…like the Undo and Redo buttons in Excel?
To undo design changes of a sheet when using the design mode, please use the Ctrl+Z/Command+Z keys. If you want to redo design changes, please use the Ctrl+Shift+Z/Command+Shift+Z keys. Please refer to this document for more details.
On the other hand, you can revert to previous versions to revert to previous sheet designs.
