Hello - I am trying to design a weekly timesheet that will cover both payroll (i.e. clock in/clock out and breaks) as well as automatically allocate hours to jobs for job costing. I am strugging with a method to make all of those pieces work.
Hi Angie
I’ve seen this template. Would it be possible to add functionality that allows an employee to scan a QR code which then starts time recording on a particular project, then re-scan to stop time recording? Ideally the employee would clock in/out at a global level, but also check in/out on individual projects.
I have been using the Timesheet template with some modifications. One thing that is really mising is the ability to have a running Elapsed time clock. A field that calculates elapsed time using NOW() will only get updated when the user makes a change to the sheet or refreshes the page.
