A couple of days ago, an update apparently made it so that the text in a field is changed to a light gray color when I hover a mouse over it. This is VERY ANNOYING. I often hover over a field to point it out to myself visually and it changing to this color makes it impossible to read. For instance, just now I was comparing a client’s demographic information with a handwritten form he had filled out to make sure they matched.
I’ve attached 2 screenshots to show what I mean. Please change this back.
Thanks for your feedback. We have modified the display of locked/read-only fields when hovered over. This helps fields with background colors to show if it is not editable when hovered over. We will see if more modifications are necessary once we have more feedback from other users.
Could you please help submit a ticket through “Need Help” at upper right corner in your database > “Support Ticket”, filling the information about this issue with your sheet/record urls and screenshot for us to look into with and see if we can find a better way to handle it?
As people usually don’t directly associate the display of a box (border) with ‘read-only,’ I’m afraid this won’t be our consideration. Thank you for your understanding.
