Has anyone ever used Ragic for collecting functional ESG data for sustainability reporting?
Hi my name is Ilias - I saw the notification on your question regarding templates of ESG content.
I have never used any template on that kind of subject, yet there is a crucial question in my humble opinion, which is - split in 2 sections:
A) Do you already have such a kind of template or not ?
IF=YES
A.1) Are you going to use any kind of automated process to gather the data and then drop them (upload etc) into the Ragic Template ? or is it going to be a manual input process?
IF=NO
A.2) Is your question based on the fact that You are going to need such a kind of template ? Which means you are looking for similar examples Ragic templates, if they exist ?
Has your organization considered designing from scratch (almost)?
Hope this helped a bit.
Best Regards.
