Subtables not syncing across Multiple-Versions
I used the Multiple versions feature on a summary sheet with a subtable. However, when adding a row to the subtable on one version of the sheet, the new row does not show up on the other version of the sheet.
I am unsure how to solve this. Is subtable syncing supported by multiple versions? Is there a setting I need to check?
Could you please check if you have applied filters on either subtable and if both subtables have the same field IDs on the subtable fields? If you have not applied filters and the subtable fields have the same field ID but the subtable data are still not in sync, please submit a support ticket via the “Need Help?” button located at the top right corner of your database to allow Ragic support to investigate this situation further.
Thank you Fabio. The issue actually seems to have resolved on it’s own. In the future I will check those things and submit a support ticket if needed.
