Subtable Total
I’m unable to figure out how to get totals at the bottom of a subtable within my forms? There are two columns that I need totals for (Fixing measure and Order measure) Can anyone help with this, im sure there is a simple solution that I’m not seeing
Hi Harry,
This is Kate from Ragic Support. You might find this article helpful—it explains how to use formulas to sum values within a subtable column. The example also demonstrates how the sum field (A16 Total) is placed directly below the subtable.
If this isn’t quite what you’re looking for, feel free to share more details about the result you’re hoping to achieve. I’ll be happy to assist further!
