Subtable - Sum
Hi There,
i got a subtable that cotain multiple column and I wanted to sum each of the column on top of the subtable.
example:
  1.  9
HKD | USD |
10. |. 3
20 |. 6
Hi Raymond,
Please take a look at this guide. Although it focuses on displaying subtable totals below each column, the same approach can be used to place the total fields above the corresponding columns instead.
Hi Katet,
Thanks for sharing. it helps.
Hope soon - Ragic will have simple way of having a total add up :slightly_smiling_face:
Cheers
