Is there anyway I can Lock a row (Record) in a subtable. Tried Locking the actual record on sheet, but can still be changed.
In a subtable, it is not possible to lock only a single row from being modified. However, you can achieve locking by setting the “Read only” property for specific columns within the subtable. This can be applied to one or multiple columns as needed.
Thank you for your understanding.
If you have a subtable field that determines whether the row should be locked, you can try conditional formatting:
https://www.ragic.com/intl/en/doc/39
