Subtable issue
The first entry of the subtotal can be a “loaded” field only or it has to be “linked” field? I have the linked filed in the main table and wanted to bring the info from the origin subtable but when it’s loaded field the data does not populate.
Hi there - could you share a couple more details for our reference?
  1. the steps to reproduce the behavior - after you set up the link and load, did you populate the link field again to trigger the loading action? Or what did you do to load the subtable field but failed?
  2. screenshots demonstrating problem behavior
If the contents are sensitive, please write to us at support@ragic.com instead. Also include the URL to the sheet in concern so we can take a closer look. Thanks!
