When you deal with many records you set starts for key records and it would be great if we could see the same starts when the records as displayed inside another form. Below is an illustration of this.
I see, you mean having able to star records on subtables. I will let our developers know about this and see if this could be added to our future releases.
Yes that is correct and to keep it simple Ragic should not care if the star was created in the main sheet or subtable so it does not need to keep separate memories of what was ticked, it is global.
Love how you are always willing to listen to us.
Thanks Jeff and the team
