I have a numeric field, and have searched for all results that have no result in that field (*blank to -1). It displays the results correctly with only blank results shown. then when I attempt to sort them via date, it adds in data that has values in this field.
Previously this was not an issue. Has only started happening recently.
Hi Adam,
Sorry that I’m not quite sure about what you mean. Would you please submit a ticket through Need Help (at upper right corner in your database) > Support ticket with below information for us to refer to?
- The sheet url you have this issue with
- Steps to reproduce this issue
- Screenshots of the steps and issue
- Click “Grant Access Right to Ragic Support Team” button
So that we can look into your database to check.
Thank you!
