Is it possible to show subtable in listing page ?
A workaround would be as below:
Step 1. Use “New Sheet from Subtable” to convert your subtable into a sub-sheet first.
https://www.ragic.com/intl/en/doc/33/
Step 2. If you need more fields from the parent sheets, you may insert them via "Link Fields from Parent Sheets.
https://www.ragic.com/intl/en/doc/56/
Step 3. Add all needed fields on the listing page of the sub-sheet.
Thank you so much. I followed the workaround Angie provided. It works !
