Setting the Excel export column order
Hi
When I export my sheet to excel the column order is different to how it shows on the screen. I would like to change this so every time I export it is in the correct order.
Any ideas?
Thanks
Andy
Ah I have found it.
Design Mode
Listing form page
It reads Left to right, top to bottom
I’ll re order there and expect it will sort it
If you want the excel to look like your ragic listing page, you can select “Fields on Listing”,
or if you want a custom order you can select “custom fields” and click the “Save custom fields setting” at the bottom. Next time you will be able to use this template to download excel.
