Looking for a new feature!
Can you please add an option for selection list options to appear in alphabetical order?
Thanks!
Thanks!
Thank you for your suggestion! We will consider this and will likely add this in our coming releases. We will keep you updated here.
Thank you so much!
How’s this coming…? After alphabetizing by hand at the start, of course we’re now getting user-submitted choices, and those appear at the bottom of the list, not alphabetized.
Airtable is able to keep selection lists alphabetized, or allow re-arranging by drag-and-drop…
I have the same request
