I have a “selection” field we’ll call X. For most of the records it is blank and I want that- makes it easy to sort and filter. Sometimes I will assign a record a value for X for a while and then want to change it back to blank but it looks like I can’t. Once a record has a value I need to give it another nonempty value. SO my question is: Is there away to do this? If not can I convert the fields to multiple selection, which does allow backwards movement, without loss of data?
Thanks!
