Good Evening Everyone,
I do apologise if this is a rather novice question, but could someone advise me how you would go about scanning a QR code from the Label Maker report tool, so that it would direct to the database entry for that code?
I have attempted it using a few QR code scanners for android but they just give a blank result.
Thanks,
Jon
Hi
In my case, I use bluetooth barcode scanner (support QRcode) connet my mobile phone or computer(need bluetooth receiver). then scan QRcode at search bar by scanner~
Hope it is useful for you~
Is there an app that can be used instead of having to purchase a handheld scanner?
Mobile phone or computer?
Mobile phone: Ragic app can scan code
Computer: Handheld scanner is best way to scan code~
