Individual record amounts and report total differing as a result of rounding. Do I need to round the records or the report. How di I round a calculated field eg A6+D16, needs to include rounding to 2 decimal places.
Any help would be appreciated.
I know it’s probably very simple, but can you give an example how to write the formula.
Round(2)A6+A7.
Hello, you can refer to this picture and enter the formula in your field.
You can refer to user amor830307’s formula examples and try them out on your fields.
