I aligned cells in a record to the top.
Issue 1. Look at data column: the date is at the top, as it should, but the button to pick the date is in the middle. I think the button should also follow alignment and be next to the date.
Issue 2. The date picker is at the bottom. If my text is long enough, it becomes an issue. Is it possible to place the picker under the picker button?
The date picker will always be located beneath its respective field. I would suggest enabling the “no wrap text” option for other fields in the same row that may have a large amount of text.
