Hi
This the first time for me to use Ragic and I’m looking for any kind of templets you recommend using for research projects and publications.
Thank you
Amal
Hi
Thank you
Amal
We do have RD Document Management template for managing document but it’s for document only. If you’re looking for research project management and publications, we would suggest creating new sheets based on your workflow, here is the first step to build your database which you could refer to.
