Sorry if I missed something and I posted another article but this is slightly different. The other post asks for reports to be listed under the main menu.
You will see we add links in each sheet header but this also is getting long. Maybe it would be easier if we can define or you can automate listing the reports on the left menu, under the reports menu along options of adding new ones, or somehow in the header in some dropdown menu.
Even if the designer needs to manually add them to the left menu for that view that will already help.
Thanks
