I have a link that I need to remove but every time I try it gives me this message "You cannot remove the link back to this sheet parent. I decided to do a customer entry form separately so that other sheets could be tied into the customer but I can’t delete the customer ID that is linked in another sheet.
I’m guessing that you have got a reference subtable on your parent sheet. In this case, you cannot remove the link and load relationship or else the reference subtable would not work at all. Therefore, if you really want to remove the link and load relationship, please remove the reference subtable on your parent sheet first, and then you’ll be able to remove the link and load relationship.
