When viewing a sheet that is filtered, adding a record removes the filter. This is the case for ‘on the fly’ filters, saved filters and even default filters. That doesn’t sound right to me, particularly for default filters - if a user wants their sheet to start up in a certain format they probably want it to be like that after adding a record, as we do. Please could you consider amending?
…just to add that this behaviour is inconsistent in that where there are two users viewing a particular sheet, and User A adds a record then her filter is removed. User B, viewing the same sheet and using the same filter continues to see the filtered results - her filter is not removed.
