Hello Guys!
Quick question: I´d like to know if On Premise option could be fully customized: URL, Logos, Emails, Notifications, etc.
Thanks!!
The white labeling options are mostly the same as cloud version.
The current difference would be url (on-premise: direct to your own server; cloud: you can use custom domain to re-direct to our server) and email sender (on-premise: you can set up your own mail server and email sender).
You can find white labeling options in Ragic in this documentation:https://www.ragic.com/intl/en/doc/67/
However, for certain email notifications e.g. user invitation, approval, entry creation or modifications are not allowed to customized no matter if it’s on-premise version or cloud one.
Thanks Amy!
