NOT STARRED!!
Hi guys,
I was just now using my favorite DB, when I realize I would have liked to select “Not Stared” as appose too “Stared”, only to realize the feature’s not supported!
So, I’m making this suggestion/Feature Request!
It would be most helpful as I use Ragic as a “Real-Estate Listing MLS” management tool!
Thanks!
Kane
Hi Kane,
Thank you for sharing your suggestion.
Just to clarify—when you mentioned that you’d like to select “Not Starred” as opposed to “Starred,” were you referring to the ability to filter or identify records that have not been starred?
We’d appreciate it if you could share more about how this feature would support your real estate listing management workflow. This context will help us evaluate the request more holistically and consider how it might benefit other users as well.
Thank you again!
Best regards,
Kate | Ragic Support
I like the “Starred” feature! As I said I use it when running cross-checks, making sure that the properties I have listed are the same across all of our external advertising websites!
As for your question, to clarify, it is a feature that I was referring to, the ability to filter records that are “Not Stared”, I currently can only filter “Starred”!
Thanks and best wishes,
Kane
Hi Kane,
Thank you for confirming!
I’ve passed your request along to our development team. Feature enhancements are reviewed holistically, taking into account factors such as user demand and technical feasibility. You’ve been added to the notification list, and we’ll leave a note here if the feature becomes available in the future.
Thank you again for your feedback!
