I’ve been struggling with Ragic for the last few days trying to get a Many to Many relationship to work…
Previously I had tried to follow these directions…
https://www.ragic.com/intl/en/doc-kb/103/Referencing-two-sheets-at-once
I know there’s a fix being worked on in regards to this so in the meantime I tried to build a Many to Many using 3 tables.
Classes
Students
Class_Student (join table holding foreign keys to both Classes and Students)
The tables looked like this…
Classes
Class ID
Class Name
Students
Student ID
Student Name
Class & Student
CS ID
Class ID
Student ID
With the “Class & Student” table I did 2 different link and loads to the “Class and Student” table.
So now the “Class & Student” table looks like this…
Class & Student
CS ID
Class ID
Class Name (loaded from Class table)
Student ID
Student Name (loaded from Students table)
I then created 2 “multiple version” from this “Class & Student” table to try to display the correct field order that I hoped would work with creating a Subtable under both the Classes and Students tables.
The first variant I called------------------------
Students & Classes 1:M
And I hid the "CS ID" primary key so that in sheet view it would look like this
Class ID Class Name
The 2nd variant I called--------------------------
Classes & Students 1:M
Likewise I hid the "CS ID" and it looks like this
Student ID Student Name
I went back to the Classes sheet and then tried to insert the “Students & Classes 1:M” sheet
into a subtable by using Link and Load.
Unfortunately it would only allow me to drag and drop the original “CS ID” primary key that I was trying to hide by using “multiple versions”.
There was no way for me to do a custom join by trying to drag and drop the Class ID from this join table into the Students subtable row.
It would be really nice to have a fix or a clear direction on how to do Many to Many relationships properly…
Thank You!
