When creating a booking, we sometimes create a new address from within the booking sheet. The Address sheet opens in a new window.
When saving the address, the system redirects back to the Booking sheet immediately — before the post-workflow has completed.
I would like to:
- Geocode the address via an external API.
- Store latitude/longitude on the address record.
- If the geocode confidence is low, allow the user to:
- Review suggested results
- Potentially adjust the coordinates manually
Nr 3 is an important step for making sure we are not getting faulty coordinates for our drivers
My understanding is that post-workflow runs after save and redirect, so it does not allow user interaction.
I therefore tried using pre-workflow, but it seems entry.setFieldValue() (or entry.set) does not work there.
Questions:
- Is it possible to modify field values in pre-workflow before saving?
- Is there a recommended pattern for validating via external API and populating suggestions before allowing save?
- Would throwing an error when confidence is low be the only supported approach?
Ideally, I would like to:
- Call the external API
- Populate suggested coordinates
- Let the user review them
- Block save only if confidence is too low and no manual override is made
Any guidance on best practice would be appreciated.
Thanks.
