Please make the scrollbar visible and email hyperlinks functional on mobile devices when embedding sheets from Ragic. Currently neither of these work on the mobile Safari browser making for a poor user experience.
Thanks!
Would you please let us know which embedding tool you are using? And do you mind sharing us with a screenshot with the issue for us to refer to?
Thanks!
It is with the Database Search embed and happens on any sheet where the number of columns exceeds the width of the page. On desktop browsers a scrollbar appears at the bottom to accommodate this and email hyperlinks are clickable. On the mobile Safari browser there is no scrollbar and email hyperlinks do not work.
Would you please let me know if you are using Android or iOS mobile device?
Thanks!
I am using an IOS mobile device with Safari browser.
I’ve tested our embed sheets on the browser from Android and iOS app and did not encounter the issues you mentioned.
Please note that if the Ragic sheet is embedded on your website, there might be some restrictions caused by the script on your own webpage.
