Hi, I am in need of help using the MAXIFS Function.
I’m referencing a subtable with a Date Field (A70), and a Select Field (B70)
I need the last date if the select field is either Perfection Ltr-Accepted or Perfection Ltr-Deficient
I’ve tried several variations including using either one as standalone:
MAXIFS(A70,B70,“Perfection Ltr-Deficient”) Working
MAXIFS(A70,B70,“Perfection Ltr-Accepted”) Working
However if I try to combine to get the latest date of either selection, it doesn’t work.
IF(B70=‘Perfection Ltr-Accepted’,MAXIFS(A70,B70,‘Perfection Ltr-Accepted’),IF(B70=‘Perfection Ltr-Deficient’,MAXIFS(A70,‘Perfection Ltr-Deficient’),‘’) Does not work
MAXIFS(A70,B70,IF(B70=‘Perfection Ltr-Accepted’,B70,IF(B70=‘Perfection Ltr-Deficient’,B70,‘’))) Works but pull the wrong date
MAXIFS(A70,B70,IF(B70=‘Perfection Ltr-Accepted’,‘Perfection Ltr-Accepted’,IF(B70=‘Perfection Ltr-Deficient’,‘Perfection Ltr-Deficient’,‘’))) Works but pull the wrong date
IF(B70=‘Perfection Ltr-Accepted’, MAXIFS(A70,B70,‘Perfection Ltr-Accepted’),IF(B70=‘Perfection Ltr-Deficient’, MAXIFS(A70,B70,‘Perfection Ltr-Deficient’),‘’)) Doesn’t Work
Is there a way for this to work? Or am I just being brain numb after hours of trying to get this to work and am missing something easy.
Thank you for you help
Robyn
