We often need to override a loaded field with a new image. Is there a way to do this. It is possible to overwrite a descrpition or numerical field but not an image field that is loaded from another sheet.
Not quite sure about what you meant. Could you please submit a ticket through “Need Help” at upper right corner in your database, fill up the form with information: 1. record url 2. steps to reproduce the issue 3. screenshot of the issue, so we can look into your database and check?
I have submitted a help ticket
