I need help making the number format stay in the mailmerge.
On my Ragic I have the money format as $#,##0.00 but on the excel it won’t show the cents if it is a whole number.
We will fix this issue next Tuesday, we will keep you posted.
We have just applied a fix on this issue that you reported. You can test it out and see if they are working as expected now.
Yes, it is working perfectly.
Very swift fix.
Thank you, Amy.
