Hi
Why is there no Javascript function to Link and load a selected linked field?
Or is there? ![]()
There is one, i am not sure if you can call it for specific field
var nodeId = param.getNewNodeId(XXX);
var path = ‘xxxxx’;
entry.loadAllLinkAndLoad();
entry.setCreateHistory(true);
entry.save();
If you need to update a specific linkAndLoad field individually, you can use:
entry.loadLinkAndLoadField(domainId)
This is a newly supported method, so it has not been added to the documentation yet. We will update the documentation accordingly.
