Hi Everyone,
Could somebody help me what should I do if I would like to add more columns in “link and load” surface than I can reach? Is there any way to scroll the page?
Thanks for your help
András
Hi Everyone,
András
Meanwhile I have found a solution: if I create a new field on the right side of the table, than the link and load view will show a larger widht.
Sorry that currently there’s no scroll bar in the Link Manager for Link & Load.
And yes, you will need to first create the fields you need on the sheet you are currently designing so that you can use Link & Load to create linking lines on them.
Ok, thank you - creating the fields first is the best solution, it will solve the question.
Thanks,
András
