I have a field that is the master link for loading other fields in the record. It has “Multiple Select” activated. If I only select one value in the master link, the other fields populate with one value as normal. But if I select a second value in the master link, all the other load fields are cleared.
Is there a way to have all the values stored in the loaded fields? Maybe separated by a comma, or as multiple select?
