Hi, I have a link and load that is generally working well. However, I just added a new field X that is not behaving. When I initially select the Linked field, X populates correctly. However, when I save X goes blank (the other fields that populated are fine). thank you!
If field X is a multi-select field, it’s a known issue that is planned to be fixed within this week. If not, please send a support ticket via “Need Help?” and share the sheet name and field name so that we can investigate further.
