Lay-out Export pdf into card
Hello all,
is it possible to change the lay-out of the pdf print card?
It’s currently not supported to configure the layout of exported pdf file of the record.
However, we do plan to support mail merge to pdf file, which you can design the desired layout of your exported result of pdf file. We will notify you once it’s online.
