Hello there! Let’s say I’d like to set the field X of every entry in a table to 0. Let’s also suppose I have 10k entries. Now, I would have to make 10k api calls and that’s the problem! Is there any way to do a mass-update through the API? I can’t find anything in the documentation.
Thank you!
You can simply use the mass update to update the field X with “0”. May I know the reason why you would like to update it through API?
Because I have to periodically set that field. Is it possible through API?
It’s currently not supported yet. But we can consider adding this support in the future. This does seem like a good alternative to writing and running daily workflow scripts.
OK! That’d be really great! Just one API call to update them all instead of many API calls.
Hi Jeff,
I’d love this function if there be.
That would be epic and save some server processing just hitting the DB.
Thanks
