So, I would like to have different webhooks in the same table, based on events. For example, when adding a new entry, call webhook A; when editing an entry, call webhook B; when deleting an entry, call webhook C. Is this possible?
Good question as you only get the nodeID. UI am new to Webhooks.
What tool are you using?
I did some quick tests using https://beeceptor.com/ and got the below results.
It is fine for a created record as you can use the API to get the new record data.
If you only get the NodeID then for updated records you don’t know what changed and even more confusing is if a record is deleted then how do you get data from the deleted record to update another application.
I suppose the same applies to Zapier.
Can anyone help us please?
Thanks
Bumping this. I am guessing that there is no way to distinguish between a “create” entry and a “Deleted” entry from the data sent to a webhook from Ragic. Can someone confirm this is a limitation?
