Hi, is Ragic TAPI Compliant ? We have a phone system i would like to connect to the Ragic Database. Our phone suppliers have asked if it is TAPI compliant.
Thanks
Thanks
I’m not sure what you mean by TAPI compliant, but we do have a Twilio integration feature in beta that can interface with a Twilio phone number to query for data and enter data in your database.
The Telephony Application Programming Interface (TAPI) is a Microsoft Windows API, which … Many PBX systems provide TAPI - compliant modem interfaces.
We want a method whereby an incomming call can be captured and used to bring up the appropriate record in our Ragic Database. Our Telephony service supports TAPI.
Thanks
OK I understand. We don’t directly support TAPI, but we do support Twilio that can pretty much do the same thing with a Twilio number.
Can we start using Twilio with Ragic today? If so, how?
Thanks in advance,
Kane
