ip range to put in firewall for sql sync
I would like to setup my firewall to only allow the expected ip range from ragic doing its sql sync, so not just anyone (any ip range) has access to my sql db through the firewall.
what is a good ip range for ragic I can use?
Hi Justin,
As the IP location differs based on your Ragic database, please write to us at support@ragic.com and provide the URL of your database. We’ll be glad to provide the corresponding IP accordingly. Thank you.
