- How to create invoice report with a background
- How to create a query for 2 tables then to be exported to excel.
- Do you mean by adding Watermarks into PDF file downloaded from Ragic?
- By querying for 2 tables, do you mean combining two different forms and export as one format? Or 2 subtables in a single form that you wish to export together into one file?
Currently the system does not support the former, as for the latter, you can refer to the feature Mail Merge.
