Hey everyone,
I am new to Ragic & have been playing around with it for the past couple of weeks. I am a developer trying to build a custom internal workflow for my team & Ragic seemed such as a solid no-code/low-code option compared to spinning up something from scratch.
I have figured out how to set up forms, link sheets & create basic approval flows — but now I am stuck trying to add more advanced logic or automation. I want to know about how far I can go using the JavaScript API and if anyone has integrated Ragic with third-party tools or external systems.
I am also doing a salesforce developer course online on the side, so I am noticing some similarities in how things are structured but Ragic definitely has its own flavor. If anyone has tips or even “what not to do” stories, I want to learn from you. Also i have check this Way to "Add New" to selection field using js workflow still want guidance.
Thank you.![]()
